NI TestStand
.Net dll and TS 3.0
I have a problem with TS 3.0 and a .Net dll. The following error occure when I try to load the dll.
"Error while accessing the .NET assembly
Index was outside the bounds of the array"
The same dll is used in LabVIEW and later versions of TestStand without any problems.
What kind of restrictions does TS 3.0 set on .Net assemblies?  Is there any datatypes, or programming logic that should be avoided?
(3,111 Views)
(3,031 Views)
