NI TestStand
NewSubProperty signed 64-bit number
I have a very simple question.
I want to create a local variable programmatically using the NewSubProperty method:
Locals.NewSubProperty("FileSize", PropValType_Number, False, 5)
If I do it, a number is created. The type I need must be signed 64 bit integer. How to do it?
(3,002 Views)
Accepted by topic author Madottati
Hi Madottati,
You can assign the local variable type using the following expression:
Locals.FileSize.Type.Representation = PropertyRepresentation_Int64
I hope this helps,
Charlie Rodway | Principal Software Engineer | Certified TestStand Architect (CTA)
Computer Controlled Solutions Ltd | NI Silver Alliance Partner | GDevCon#1 Sponsor
(2,986 Views)
You can also do:
Locals.SetValInteger64("MyVar", PropOption_InsertIfMissing, 123i64)
Hope this helps,
-Doug
(2,974 Views)
