NI TestStand
Ni-DAQ 7.1 and CVI Function panels
I have an XP system running TestStand 1.0.3 with CVI 6.0, and hardware NI-4070 and NI-6713. I have downloaded NI-DAQ 7.1 driver. However, I cannot find any CVI function panels for the DAQ. During the installation, I selected CVI and all it's subfeatures, but I did not see any installed.
(2,952 Views)
To offer support for driver upgrades. the NI-DAQ installer is the one that installs the DAQ libraries for CVI. The first thing to try is to run the NI-DAQ installer from the add/remove programms applet and make sure that support for CVI is selected.
FYI: CVI 6.0 only supports the Traditional DAQ driver, to use DAQmx you would need to upgrade to CVI 7.0; click here for more info.
I hope this helps.
Juan Carlos
N.I.
(2,952 Views)
