NI TestStand
No access on global variables in sequence calls
I have the following problem:
I don't have access on global variables (Fileglobals.xx) in subsequences.
I had access on the global variables until I add a big array to the global variables.
Is this the reason for that strange behavior?
thank you for your help
Samuel
(4,051 Views)
How big?
Are the subSequences in seperate sequence files?
What TestStand version are you using?
Regards
Ray Farmer
Regards
Ray Farmer
(4,042 Views)
Hello Ray,
1)
I had two string arrays with: array1[0....11][0...800], array2[0...6][0.....400]
until this everything was ok
then I increased the array1 to array1[0....11][0...1200]
from this point I had the problem
2)
No the subsequences are in the same sequence file
3)
I am using teststand 3.1
would it be better for this probelm to use teststand 3.5?
Thank You for your help
regards
Samuel
(4,034 Views)
Samuel,
How are you accessing the FileGobals, is via the expression step or an TS API GetVal method.
Regards
Ray Farmer
Regards
Ray Farmer
(4,031 Views)
hello ray,
everithing is ok now...i have solved the problem
regards samuel
(4,026 Views)
Samuel,
Are you able to share your information?
No Problem, glad you got it sorted.
Regards
Ray Farmer
Regards
Ray Farmer
(4,022 Views)
Ray,
yes of course I share the information.
I double clicked on the sequence calls, then I clicked on "specify Module". There I enabled the clickbox "Use current File"
From this point I had again access on the fileglobals in the subroutines
regards
samuel
(4,016 Views)
