NI TestStand
No corresponding subproperty in argument 'Locals.PSU_Array<Array Element Prototype>' of type 'PSU_Cluster_v5' for cluster element 'PSU_Array Output<Array Element Prototype>.VISA resource name'
Hi folks does anyone know how to resolve this error. I have older versions where the PSU array is fine, but on opening an older sequence at same time as having this faulty sequence open then the old one becomes fault as well.
Message : No corresponding subproperty in argument 'Locals.PSU_Array<Array Element Prototype>' of type 'PSU_Cluster_v5' for cluster element 'PSU_Array Output<Array Element Prototype>.VISA resource name'
File : C:\LABVIEW\Adum770x_all\dan\Teststand\Sequences\ADuM7702_Gain_INL.seq
Location : Seq["MainSequence"].Main["Enter Sequence Parameters"].TS.SData.ViCall.Parms["PSU_Array Output"].ArgVal
Rule : Step properties must have valid values
Description : All step properties must have valid values. Invalid property values can cause errors at run time.
Use the Step Settings pane to set the property to a valid value. Ignore this message if the property
will be set dynamically to a correct value at run time.
(2,357 Views)
If you open the good sequencefile first then open the bad sequencefile you should get a dialog where you can select which data type to use for the second sequencefile. Select the data type from the first sequence file.
Don’t forget to save the second sequencefile.
Regards
Ray Farmer
(2,293 Views)
