NI TestStand
No warning for missing parameter?
Is this normal that TestStand gives no warning that a parameter is missing?
I"m using it (TS3.5) with CVI (8.0).  The CVI function had one extra parameter that TestSTand didn't include.
Rafi
(3,225 Views)
Hey Rafi,
I'm assuming what you are talking about is in the Specify Module window within TestStand it was automatically populating the parameters for your function, and it was missing one of the parameters? Could you post exactly what your function prototype is here as it is declared in CVI?  Also which parameter is missing from the TestStand side?
Pat P.
Software Engineer
(3,203 Views)
