NI TestStand
Not able to read AddtionalResult.requirments
am using the followwing code
voidaxApplicationMgr_UIMessageEvent(objectsender,NationalInstruments.TestStand.Interop.UI.Ax._ApplicationMgrEvents_UIMessageEventEvente)
if (e.uiMsg.Event ==UIMessageCodes.UIMsg_Trace)
try
intframeid;
SequenceContext seqctx = e.uiMsg.Thread.GetSequenceContext(0, outframeid);
if(seqctx.PreviousStepIndex >= 0)
Stepprvstp = seqctx.PreviousStep;
StepTypeprvstptyp = prvstp.StepType;
PropertyObjectstepPropertyObject = prvstp.AsPropertyObject();
String testid=String.Empty;
if (string.Equals(prvstptyp.Name, "NumericLimitTest"))
testid = stepPropertyObject.GetValString("Result.AdditionalResults[\"Requirements\"]", 0);
double lwlimt = stepPropertyObject.GetValNumber("Limits.Low", 0);
double measValue = stepPropertyObject.GetValNumber("Result.Numeric", 0);
String unit = stepPropertyObject.GetValString("Result.Units", 0);
am not able to read the Requirments by "testid = stepPropertyObject.GetValString("Result.AdditionalResults[\"Requirements\"]", 0);"
but am sucessful in reading all others.
can you please help me in this regards.
IVI
(2,794 Views)
IVI,
please do not open new threads for the same topic......thanks
The discussion is kept there.
thanks,
Norbert
Norbert
Expert: Geometry
(2,791 Views)
