NI TestStand
Not all results in the same file.
Hi Experts,
Can I force TestStand (TS2018) to write each and every result from four different sockets to separate files in parallel mode?
 -jake-
(2,088 Views)
So you want a file for each result?  Or just a file for each socket?
Socket is easy as that is built into the result processing plugin.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,062 Views)
Thank you. I needed separate report for each run of a test sequence. So, just a file for each socket.
Now it would be nice if I could modify the "serial number", before it is automatically included in the name of the test report file.
Do you know which parameters is used for that? Or where this change is most convenient to perform?
(2,039 Views)
You can use different things for the file name.  Hope this helps.
jigg
CTA, CLA
testeract.com
(2,020 Views)
Thanks for your help, jigg. My problem is this.
I don't give the serial in the dialog, instead I read it during the test (from the UUT).
Then I get [Empty_Serial_Number] in the place of serial number in report file name.
Trying to find the place to replace that, but haven't been able to do that so far.
And another correction to my original message, I am running TS2014 not TS2018, sorry.
Does that make any difference?
(2,000 Views)
Problem solved. Figured it out by myself.
(1,966 Views)
