NI TestStand
Not possible to edit input and output parameters when added a Vi as module in the step Pass\Fail Test.
I added a Vi as module in the step Pass\Fail test.But No parameter name is displayed.Also not possible to specify the input&Output parameters in the module tab of step settings pane.
[Adapter is Labview]
Please suggest how can I assign the input and out put value of a .VI to a global variable in Teststand.
Thanks.
(3,005 Views)
What terminals do you have connected on your VI?
This picture shows how to assign StationGlobals.
Message Edited by ~jiggawax~ on 07-16-2009 09:37 AM
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,997 Views)
