NI TestStand
Not receiving UIMsg_ProgressPercent messages
I've got a custom UI running in LabView and I receive Trace messages left and right as normal, but I never receive any Progress Percent messages. I'm using Message polling and every message I receive is written to a debug file, so I know all the messages I'm receiving. Is there some option I have to set to have TestStand send me UIMsg_ProgressPercent messages or do I have to explicitly send those messages myself in the sequence?
(3,139 Views)
It is up to you to explicitly send the ProgressPercent UIMessage. You operator interface or the sequence editor then updates your progress bar with the value sent with the UIMessage.
The most common use of this UIMessage is in generating reports. This is implemented as part of the process model. If you are using the DLL option to generate the report (see Configure>>Report Options) then you will have to look in \Components\NI\Models\TestStandModels\modelsupport2.dll to find the posting of the ProgressPercent message. Or, if you are using the sequence option to produce an Web Page report then you will find a Display Progress Percent step in PutResultsInReport sequence that is within \Components\NI\Models\TestStandModels\reportgen_html.seq. Either
way, the concept is the same. As the code recursively processes the result data in building the report body, it sends out a different ProgressPercent with each iteration. Your OI receives this and correspondingly updates the progress bar to display the correct progress.
(3,139 Views)
