NI TestStand
Numeric format in the execution view
Hi guys,
How to set the numeric format in the execution view?
(3,596 Views)
That is dictated by whatever is in Numeric Format in the Step Settings under Limits.  Check out the screenshot.  You can click on the drop down and customize to whatever you'd like using the standard c style string syntax.
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,572 Views)
