NI TestStand
Numeric limit test without a VI?
I have a measurement that was stored as a variable in a previous step and now I need to put it in a numeric limit test. How do I do this without a VI?
(2,595 Views)
You can do this easily by changing the adapter type to <NONE> and inserting a Numeric Limit Test:
If you've already inserted a Numeric Limit Test as a LabVIEW module (VI), you can change the adapter type on the Properties tab of Step Settings:
Edit the Data Source to point to your variable, eg.
I hope this helps,
Charlie Rodway | Principal Software Engineer | Certified TestStand Architect (CTA)
Computer Controlled Solutions Ltd | NI Silver Alliance Partner | GDevCon#1 Sponsor
(2,549 Views)
