NI TestStand
Object reference not set, Or not a .net object error
Object reference not set error when calling VB.net class. Also when I specify an object in Test stand and don't create an object Teststand thinks it isn't a .net object. I don't see how this can be since my step is specifing a .net module?
(3,175 Views)
Object reference not set error when calling VB.net class - I do not get any errors calling into VB.net code.
Also when I specify an object in Test stand and don't create an object Teststand thinks it isn't a .net object. I don't see how this can be since my step is specifing a .net module?" - I am not sure what you are doing here.
To help you, I need more information. Can you attach a sample sequence with a sample assembly that demonstrates this problem?
(3,175 Views)
