NI TestStand
Obtain Value of Arbitrary TestStand Variable with Arbitrary Data type from LabVIEW?
I have a need to take a variable name, let's say:
Locals.Variable
and then from LabVIEW, retrieve its value regardless of data type (so a variant).  I tried to do this with the method
GetValVariant
but occasionally will receive an error:
-17308 Specified value does not have the expected type
 I'm wondering why this happens if a variant can handle any arbitrary type and if there is a way around this?
I saw my father do some work on a car once as a kid and I asked him "How did you know how to do that?" He responded "I didn't, I had to figure it out."
(2,518 Views)
Here it is a previous forum that shows a similar issue
https://forums.ni.com/t5/NI-TestStand/Specified-Value-Does-not-have-the-Expected-Type/td-p/389290
This can be useful for you.
(2,475 Views)
Similar but not quite the same.  In my case, the variable in question is a container with all its elements predefined, none are dynamically added as is the case with the ResultList.
I did however resolve this by using the GetXML method instead which seems to handle any type of variable regardless of structure.
(2,472 Views)
