NI TestStand
Offline results processing and custom CommonResults
Hello
I have added a custom field to the CommonResults data type and added the corresponding column on my database STEP_RESULT table. I added Columns/Parameters  to save it but the offline results processing doesn't store it to the database.
In column/parameters I added:
Expected properties: Logging.UUTResult.Common.FIELDNAME
Expression: Logging.UUTResult.Common.FIELDNAME
Does the offline results processing support custom fields?
Yannick
Message 1 of 1
(4,288 Views)
