NI TestStand
On what factors i distinguish Labview from NI Teststand?
what exactly the difference between the Labview & ni teststand?
Can they be used in similar fashion?
(3,062 Views)
You're comparing apples and oranges. TestStand is a test manager for controlling execution of test steps written in any number of programming languages, including LabVIEW. TestStand handles the ordering of test steps, report generation, datalogging. You would use LabVIEW (or CVI, .NET, VB, etc.) to create the actual test steps that communicate with your UUT and instruments. If you have to develop a lot of test sequences, you should consider purchasing both.
(3,062 Views)
