NI TestStand
Open VI from Test Stand
I have a sequence file containing several actions and tests calling LabVIEW VIs. Is there a way to open these VIs directly from TestStand to edit/study them? The only way I have found so far is to copy the VI path to an explorer window, which works but its a bit slow. I guess there is an easier way to open a module in its editor.
(I bet this question had been asked couple times, but I have not yet found the answer)
thx!
(5,031 Views)
Accepted by topic author 1984
Hi 1984
Yep you can do it from the TestStand Sequence Editor.  Select the step you want to edit and use the button highlighted (with the red ring) below.
NOTE: If the button is disabled, you need to change your LabVIEW Adaptor settings.
Hope this helps
Steve
(5,023 Views)
You can also right click on a step and select Edit Code from the menu.
(5,012 Views)
Works like a charm, thanks!
(5,008 Views)
