NI TestStand
Open sequence file to add break point in custom UI
I would like to open a sequence file in my UI to let the operator insert a breakpoint. I am customizing the Simple UI shipped with TS 4.0.
By now I can insert a breakpoint in the Sequence Display by using the IsEditor property node at IApplicationMgr but I am not allowed to open a sequence file from the Sequence Display. As I double-click the sequence I only get the properties dialog. All this as the OI is running.
See attached screen dump.
(3,705 Views)
Hi deuter,
This is expected behavior. You cannot edit the Sequence File, when it is still running.
Regards
MY
(3,678 Views)
Thanks for your answer, My NI.
(3,657 Views)
