NI TestStand
Opened SQL sessions
We're seeing in the factory a problem with the SQL server, so IT guys asked to check the opened SQL sessions and see if we can close them after testing a unit.
Is there a way that I can close the connection to the database every execution? I was checking around and found this:
Re-establishing TestStand Database Connections: Does anyone know exactly how TestStand maintains its...
but doesn't works for me. The first time I test a unit TestStand opens 2 session, and then one per unit. The method in the link only "kills" one sessions of the first time execution.
TestStand 2014
SequentialModel
Non-OTF
Windows 10
Database MS SQL Server
Message 1 of 1
(1,158 Views)
