NI TestStand
Opening a Word document using Teststand 2010?
I need help to open a word document using Teststand 2010. Any help would be greatly appreciated.
WJ
(5,239 Views)
Hi WJ,
What exactly are you hoping to do with the Word document?  Do you want to read and write data to it?  Or open a TestStand report in it?
If you are hoping to manipulate a Word document or text file in general, I would recommend developing a code module in another language (LabVIEW, CVI, etc.) to do the lower level manipulation, and then use TestStand to call the code module.  In general TestStand is a test executive that is meant to integrate code modules written in various languages into one test sequence.   More information on code module best practices can be found here:
https://www.ni.com/en/support/documentation/supplemental/09/teststand-code-module-development-best-p...
(5,205 Views)
Hi Lindsey,
Thanks for your reply, all I wanted to do is to open the word document and read it which contains instructions that need to be followed by an operator.
WJ
(5,199 Views)
Hi WJ,
I would recommend creating a code module that opens the Word document and parses the text in it.  This function could return a string containing the text you want to display.  Then use an Action step in TestStand to call the code module and save the string in a local variable.  You could then display this text to the end user with a Message Popup step.
(5,132 Views)
Thanks for all your replies, I think I have accomplished my goal using the call Executable see picture below
(5,118 Views)
