Home
Community
Discussion Forums
Most Active Software Boards
NI TestStand
Topic
NI TestStand
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Opening a sequence takes too long to load
Levente
Member
09-24-2007
03:31 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
TestStand 3.1 sequence takes very long (4 minutes) to load. Same sequence takes a few seconds only at another PC.
The delay is at a Thread.PostUIMessage ActiveX call.
Any idea, what's wrong?
Thanks!
0
Kudos
Message
1
of 3
(3,155 Views)
Reply
Re: Opening a sequence takes too long to load
RayFarmer
Trusted Enthusiast
09-24-2007
03:41 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Do you have some network paths in you TestStand Search Directories, if so you might try removing them.
Regards
Ray
Regards
Ray Farmer
0
Kudos
Message
2
of 3
(3,152 Views)
Reply
Levente
Member
Author
09-28-2007
08:36 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
A path was placed at the first place in the search directories by mistake. That caused the sequence to look into each subdirectory.
Thanks for your reply, it was helpful.
0
Kudos
Message
3
of 3
(3,123 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
