NI TestStand
Opening ini files
Hi everyone,
I need to access files (preferably ini or .txt) from CVI. I have searched this site but could only find read/write to excell files. Is there anyone who could either point me in the right direction or provide some samples. Thanks!
Kat
(6,137 Views)
Did you search the CVI board for 'ini file'? I did and came up with 118 results.
There is an entire set of ini file functions in toolslib\toolbox. Load the .fp file.
p.s. For CVI questions, you should post to the CVI board.
(6,123 Views)
Omg, sorry, that was a typo. I know how to handle ini files in CVI. I meant to say Test Stand.
~Kat
(6,117 Views)
Okay, I figure it out.
Test Stand can have access to any CVI tools by
1.) Create and action
2.) Locate the .obj of the library you wish to use.  //I don't have the .dlls for these libraries
3.) Perform the same function calls as if you are writing code.
I can't believe I missed that.
(6,115 Views)
Nevermind, the inifile.obj doesn't work. I get wierd parameters that don't make sense. Can anyone point me in the direction to find the .dlls which contains functions like
ini_New(int)
ini_ReadFromFile(string, string)
Or explain why I get crazy parameters from the .obj file?
(6,114 Views)
What I do in TestStand is to call kernel32.dll and GetPrivateProfileStringA. Here's a simple example.
(6,110 Views)
small corrections (TS2010SP1)
(5,308 Views)
