NI TestStand
Operator Interface Crashed LabVIEW
TestStand 2014, LabVIEW 2013.
I am using the Simple Operator Interface (LV) to launch my TS sequence. The first time I open it and click Test UUT's the test runs just fine. I am using the Batch Model and can continue to test units. But if I stop the OI and then run it again, when I click Test UUT's LV crashes instantly with no warning. Yesterday all was working fine. Today the only thing I have changed is I added in UIMessaging from TestStand in many steps. When this started I had a UI that was doing something with those messages. I thought that may have been the problem so I went back to the most basic included OI. It is still happening.  Any ideas of why LV would crash when I try to Test UUT's the second time? Below is an example of how I am sending the UIMessage.
In Pre/Post Expression, depending on the step, I have
RunState.Thread.PostUIMessageEx(
  UIMsg_UserMessageBase+1,
  0,
  "String to Send",
  Nothing,
  True)
Jesse
(5,446 Views)
Update.
I have tried a new file in the same Operator Interface and it works fine.
With the original sequence file I launch the VI, press Test UUTs, it runs. I can run as many UUTs as i need. Stop the VI after the run finishes. Run the VI again, press Test UUT's and CRASH. LabVIEW closes immediately and when I open it again it is in recovery mode.
NOW, if I run the VI just like above but after I stop it I completely close out of LV, then reopen from scratch it works again for one batch.
Any ideas? I think it must be something in the sequence file that is doing it because everything works fine with a new file with just one step.
Jesse
(5,424 Views)
Are you closing all the resources at the end of the sequence?
(5,335 Views)
I am unsure. I have more info which does seem to point to that. Now when I open the OI I get a warning "Some sequence files were not released the last time the TestStand Engine was destroyed". Where should this be done? If I manually close the sequence file, by pressing  "Close Sequence File" button in OI before Exiting the OI, this warning does not show up the next time.
Thank you,
Jesse
(5,331 Views)
This forum may help you, I think it was the same issue and it was solved.
https://forums.ni.com/t5/NI-TestStand/TestStand-Warning-message/td-p/12566
(5,305 Views)
