NI TestStand
Operator Interface Files
I have 2 different UUT's Tested on the same Station.  Thru this Discus Grp I was shown a way to hardcode in the path to the file of the seq I wanted to test.  This was so the operator didn't have to navigate to 2 different files(seq's).  I created 2 different Simple OI each with a diff seq hardcoded.  When I create the "exe" the supporting files seem to be just the OI files.  Should I also include the seq I'm testing along w the vi's that TS uses??  Both seq.s seem to run fine.  I didn't know if it was just a coincidnce that I was getting the correct vis when I need them because I was on the Develop Machine and not the target.
(3,275 Views)
I would say normally you wouldn't deploy your test sequence files and code modules with your OI.
But in this case, as your OI is linked to a specific sequence file then include all the test components with the deployment of the OI.
Regards
Ray Farmer
Regards
Ray Farmer
(3,274 Views)
Build your OI exe in LabVIEW. Then use the TS deployment utility to distribute all and include your EXE in the deployment.
Joe.
"NOTHING IS EVER EASY"
(3,244 Views)
