NI TestStand
Operator Interface Report
I’m currently in the process of modifying the TestStand 3.5 CVI Operator Interface (using CVI 8.0.1).
At the end of the execution I would like to copy the created Test Report from the system on which it was generated to another system on the network.  I’ve wrote a routine to do this which requires the report filename.  Is it possible using the TestStand API functions provided to get the filename of the report that has just been created?
Thanks in advance,
James.
(2,983 Views)
Thanks for posting your query on the National Instruments discussion forums.
I think the following might be what you are after:  RunState.Root.Locals.ReportFilePath
I hope this helps!
Kirtesh Mistry
National Instruments UK & Ireland
(2,940 Views)
