NI TestStand
Operator Interface execution viewing
Hi
I got a sequence which calls other sequence files in a new execution.
How can i display the trace of the new execution only in the operator interface ?
Help share your knowlegde
(2,930 Views)
Hi Shako,
For each execution you will have a tab created and as such you will see all of them available for you to view. If you do not want this to occur try just having it run in a new thread. This allows it run in the same execution but in separate threads. I hope that this helps.
Perry S.
(2,908 Views)
Putting the following expression in the thread of the new execution may accomplish what you want:
RunState.Execution.ForegroundThread = RunState.Thread
Jim
(2,897 Views)
