06-01-2010 01:48 PM
Solved! Go to Solution.
06-02-2010 01:21 PM
Hi Skeptical,
Could you be more specific as to what you mean by it appears to be "incomplete"?
I attached a screenshot of what I see in the TestStand Engine Options window. Do you see something different?
06-07-2010 01:58 PM
My first clue that the deployment installation was somehow incomplete was that when trying to run a sequence in my UI, I would get an exception that it could not find modelsupport2.dll (or something like that). When I installed the full version of TestStand, it worked.
When I look at the Optional TestStand Engine Features all I get is the hand with the pointing index finger for a cursor and nothing in the box where all the options should be.
For what it is worth, on another machine I do see all the expected TestStand engine featuers in the deployment tool.
Thanks.
06-07-2010 03:10 PM
Attached is a screenshot of the error I get when I try to open an older (created with 4.1.1) TSD file in the Deployment tool.
06-08-2010 06:01 PM
06-10-2010 11:51 AM
06-11-2010 05:25 PM
Is this a fresh installation of 4.2.1 on a new computer, or is it the same computer you had 4.1.1 on?
If it's the same computer, can you open the 4.1.1 TSD file in 4.1.1 without a problem?
This is very strange behavior and am continuing to look into it on my end.
06-14-2010 03:22 PM
I figured out the problem through a series of experiments and accidents. The short story is this:
This was not a fresh install. I had 4.1.1 on the machine. While using 4.1.1 I moved the TestStand Cfg directory to a different location. We do this to fit our business needs with regard to configuration control. When I installed 4.2.1 I intended to use all the same files in the Cfg directory so our settings would remain the same. As it turns out, the EngineParts.ini file is not compatible between these 2 versions. When I deleted the EngineParts.ini file everything works fine (so far) and the EngineParts.ini file got regenerated.
That actually is reasonable to me that the EngineParts.ini would be different between versions.
Problem solved.
06-15-2010 09:04 AM
11-10-2011 11:53 AM
Is this feature "Optional TestStand Engine" and the file EngineParts.ini found in versions PRIOR to 4.2?
thanks
