NI TestStand
P/F Test Step Post Expression Issue
I have a Pass/Fail test step in my sequence.  In the Post Expression of the step I want to assign a FileGlobal boolean variable with the step result.
In the Post Expression I have the following statement:
In the step passes, the post expression does not set the FileGlobals.TestPassed boolean = True.  Why is that not the case?  How do I resolve this issue? Thanks!
(1,269 Views)
What does the data source expression for this test look like?
(1,202 Views)
Hi Oli, the data expression looks like this:
(#NoValidation(Locals.PartNumber) == (Locals.ScannedPartNumber))
I guess I could use in the Post Expression the same expression to set the test passed boolean.  I figured I could use Step.Result.PassFail since the statement FileGlobals.TestPassed = Step.Result.PassFail is in the Post Expression of the step.  However, the test passed variable never changes.  Very confused by this.
(1,194 Views)
Your test is a "None Adapter" step; put this in your post expression, and you should get what you want:
#NoValidation,
FileGlobals.TestPassed = Step.Result.PassFail = (Locals.PartNumber == Locals.ScannedPartNumber)
(1,186 Views)
Its a "None" adapter step but it is a "None" adapter Pass/Fail test step.  Since my "data source" experssion statement is
I'd assume the step would then update the Step.Result.PassFail boolean = True.  However, when I put in the post expression
TestPassed always stays false.
(1,162 Views)
Change your Data Source to
(1,150 Views)
