NI TestStand
POP UP Message settings
How to add comments in Failure pop up message in NI test stand Version 2.0
(5,646 Views)
Accepted by topic author Dhaya2015
You're talking about the pass/fail message at the end of the sequence? These are part of modelsupport2.dll which is created with cvi. The source code is provided. You could also override the process model callback and use messages that you create with whatever programming language you are using. Editing the process model itself is also a possibility. This is what I did and used a pop-up that could display additional text, a static image, or a video. Sorry, I no longer have access to the source code.
(5,598 Views)
I Want to add additional comments in test failure dialog box in Ni test stand 2.0. can provide a solution for regarding this?....
(5,491 Views)
Where exactly are you struggling? What programming language are you using? Where will the comments come from? From a parameter you pass to the callback?
(5,482 Views)
I add one sample image and i need to add comment in that dialog box. Provide your comments
(5,457 Views)
let help to add comments in dialog box and sample pic in previous conservation
(5,414 Views)
