NI TestStand
PXIe-4141 'Initialize & Power-up' Run-time error
I'm using a PXIe-4141 on a PXIe-1085 chassis with Teststand 2019.  Whenever I try to run a test, I get a run-time error (code -1074118656) that says "niDCPower  Initialize With Channels.viDevice was not recognized."
(1,186 Views)
Looks like the Alias you passed into the Initialize API was not matching with the actual Alias available on the system.
Verify the Alias passed in and the alias configured in NI MAX
Moreover, attaching the actual files will be helpful for us to guide you better than debugging the whole stuff in our dream land!
Santhosh
Soliton Technologies
(1,178 Views)
