NI TestStand
Parallel test uut
HI,
I want to change parallel test uut screen. How can i do it?
Message 1 of 10
(5,453 Views)
The source is provided. You need LabWindows/CVI to edit it and rebuild the project as a dll.
Message 2 of 10
(5,440 Views)
Do you have link this program. How can i do it
Message 3 of 10
(5,435 Views)
It's an NI product. It's a c compiler. What are you using now for code modules?
Message 4 of 10
(5,418 Views)
I dont use c complier. do you have trial version
Message 5 of 10
(5,359 Views)
I download CVI. Which file include parallel test UUT screen?
Message 6 of 10
(5,353 Views)
I don't have TestStand in front of me so I can't provide the exact path. It's a CVI project called modelsupport2. You'll need to take some lessons for CVI. Since I don't know what exactly you want to change, you might have to change one or more files in the project.
Message 7 of 10
(5,332 Views)
Ergin,
On my machine with TestStand 2013, the Parallel UUT dialog is in a file called paralleluutdlg.c at the following path: C:\Program Files (x86)\National Instruments\TestStand 2013\Components\Models\TestStandModels. Your path may differ slightly if you're on a 32-bit machine or if you have a different version of TestStand.
What type of change are you wanting to make to the dialog?
Message 8 of 10
(5,281 Views)
You can also just override the dialog with code in a sequence using callbacks, replacing it with whatever you want. See the example:
<TestStandPublic>\Examples\ProcessModels\ParallelModel\OverrideSerialNumForParallelModel.seq
-Doug
Message 9 of 10
(5,275 Views)
Thanks for help. I want to change parallel uut screen. I did it with labwindows/cvi. 🙂
Message 10 of 10
(5,265 Views)
