NI TestStand
Parse XML File in TestStand
I've generated an XML file from TestStand (Attached in zip file). This XML file has the same tag name with different space indents.
Is there any way to get the details in LabVIEW easily (Like Get all Parent names in first indent etc)
(4,080 Views)
You can use the XML parser in LabVIEW to get that information.  Below is an example program to get all of the names within MyContainer1; it returns an array with "MySubContainer1,MyString1".
(4,006 Views)
Thanks a lot, pulidotech.
I'm able to get the String Name but is there any way values too.
Ultimately I need XML conversion in LabVIEW as an shown in attachment.
(3,991 Views)
The search string can be modified such that you can go as far down as you wish.  For example, to get the value of MyNumber1, you could change the search string to:
/Prop[@Name='Parameters']/Prop[@Name='MyContainer1']/Prop[@Name='MySubContainer1']/Prop[@Name='MyNumber1']/Value
(3,969 Views)
