NI TestStand
Pass Cluster from LabVIEW OI to TestSTand
Hi Everyone,
I m facing an issue while passing cluster from LabVIEW IO to TestStand.
The cluster contains a DVR Ref ,String Array and Numeric Array etc as per the below image.
I m using below method to write the values to TS variable from LabVIEW OI ,its in user message 10001.
using below method to read the data from TS Code module.
But while reading I m getting error from TS variable.
is there any issue in this method?
-Vipinraj
Message 1 of 1
(940 Views)
