12-20-2006 08:42 AM
12-21-2006
12:03 PM
- last edited on
10-25-2024
11:58 AM
by
Content Cleaner
Hi wheatonne,
See here and here.
02-12-2007 11:43 AM
I was not able to display Pass or Fail as part of the file name using either of the links you provided. Please provide an example.
Thank you
Neil
02-13-2007 11:26 AM
02-13-2007 02:55 PM
The point to remember is, the file ia actually generated before the call to MainSequence and then the result are written to the file after the return from the client file.
The point which the file path is generated is at a step called 'Determine Report File Path' and this step actually generates an empty file based on the information from the ReportOptions.
Therefore if you want to include the status as part of the filename, you will have to modify the ProcessModel sequencefile by moving the step 'Determine Report File Path' to a point after the return from 'MainSequence Callback' and before you Write the UUT Report and also modifying the report file name by including the status to Locals.ReportFilePath.
Hope this helps
Regards
Ray Farmer
06-05-2009
10:26 AM
- last edited on
10-30-2024
12:13 PM
by
Content Cleaner
Just an update: <UUTStatus> macro, you could specify that reports for UUTs that Pass versus those that Fail go to different locations. |
