NI TestStand
Pass / Fail step post action - option to retest step / fail step / abort sequence on fail.
Hi there....
In my main sequence there are a number of Pass / Fail steps, preceeding this an instruction telling an operator to connect cables etc.
What I would like to do;
If after executing a step the result is a Fail, we would like the option to retest, or, fail step and continue, or, abort  the sequence (incase of operator forgetting to connect a UUT correctly etc)
I'm a little out of my depth here in terms of how we could configure this in the "Step > Properties > Post Action" to give us these sort of options, or indeed if there is a different / better way of doing this altogether.
TIA.
Jim.
LABOR OMNIA VINCIT
(4,738 Views)
Accepted by topic author jimbobaggies
Do not use the Post Action.  There is a callback for this very thing.
This example demonstrates what you are looking for:
http://zone.ni.com/reference/en-XX/help/370052N-01/tsexamples/infotopics/callbacks_sequencefileposts...
Let me know if you have any quesitons about it.
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,723 Views)
