NI TestStand
Pass/fail by date
Hello Everyone,
Attached is small part of a larger program. I am trying to display the pass and fail data for the days testing. The correct pass/fail data must be displayed for the day even when the VI is closed and reopened.
I would be really gratefull if someone can help me write a simply VI to do this.
Thank you!
Maiz
(4,621 Views)
looking at the VI shell you provided the first thing that comes to mind is that the date is not stored as part of the data structure.   Its hard to sort on missing data.
Wire Warrior
Behold the power of LabVIEW as my army of Roomba minions streaks across the floor!
(4,606 Views)
It's very simple if you store to a database. No code module is required. You would just use the built-in database steps.
(4,600 Views)
