NI TestStand
Passing LVRefNum types between labview DLL and Teststand
I have a DLL written in labview which passes a LVRefNum out (object reference that contains a handle for a hardware session). TestStand won't recognise this data type and no manner of fettling or adding Custom data types to Teststand seems to work.
It works in CVI fine by declaring a LVRefNum as an u32 via "MagicCookie" in extcode.h
Anyone any ideas?
(2,559 Views)
Anyone? Is there a solution to this or not, seems strange that NI data types in Labview and CVi aren't compatible with Teststand. They're just u32s at the end of the day.
(2,532 Views)
I am not an expert in TestStand, but I was looking into this and found a similar forum thread. Although it is from some time ago, it seems to me that it is quite relevant to you still. Check it out here:
https://forums.ni.com/t5/NI-TestStand/How-to-auto-recognize-the-function-parameters-called-from-a-DL...
I hope this helps.
Kind regards,
Ruta
(2,515 Views)
