NI TestStand
Passing Strings between VI's in TestStand
I'm having great difficulty passing the following string using TestStand:  3051 0E 00 0103212A 01 02 09
-If I wire an output of on vi containing this string to the input of another vi INSIDE a LabView vi, it passes successfully.
-If, however, I attempt to pass this from the output of one vi to the input of another, it truncates the passed string to:  3051 0E .
If I convert this string to an array of hex numbers, it passes without fail.  Of course, I can define number of elements in the array to include all values, but I am unable to find any such settings for the length of a passed string.
Any ideas?
(3,417 Views)
You need to change the parameter from an ASCII string to a Binary string when you configure the VIs.  Look for the column that says ASCII string and change that on the parameters.
Allen P.
NI
(3,416 Views)
