NI TestStand
Passing Strings to an array of string doesn't dynamically load the array in Teststand
I am trying to pass a string variable to an array of string in Teststand and it doesn't seem to load the array dynamically vs if I were to pass the strings in a literal format.
I have attached screen shots. I think it's to do with how Teststand does the conversion for a string variable vs literally typed out string array
Please advise.
(2,855 Views)
Set ListOfStrings = {"061", "062", "063", "06F"}
Pass Evaluate(FileGlobals.ListOfStrings) as the parameter.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,842 Views)
Accepted by topic author fz86
If you don't want the brackets in your fileglobal variable then you can remove them and pass
Evaluate("{" + FileGlobals.ListOfStrings + "}")
Hope this helps,
jigg
CTA, CLA
testeract.com
(2,840 Views)
That worked. I was almost on the verge of using the split function to pass the string into the array...
Thank you!!
(2,837 Views)
