07-23-2010 07:02 AM
How do you pass a VI handle (reference number) from one TestStand step to another?
Thanks in advance.
07-23-2010 02:35 PM
Basically in your step (i.e.intialize) you would take the output handle and create a teststand local variable of LabVIEWIO control type. Click on the expression browser button when you are configuring your step module output. Also see here .
07-26-2010 10:37 AM
I would instead use a local variable of type 'Number' not a LabVIEW IO Control type:
When I mapped a VI that outputs a VI Reference, TestStand automatically gave it a type of Number ( U32 ).
See attached picture.
It depends on your usage of the handle, it actually may be beneficial to save the Reference in a FileGlobal if you intend to use it within multiple sequences.
PH
