NI TestStand
Passing a FPGA Reference Back and forth from Test Stand
I am trying to pass a reference to a FPGA module from one step so I can start  an action in one step and stop it, or modify it in a latter step.  I Need to create a type for the FPGA VI
Reference but I can't seem to get the right type does anyone know how to do this?
Bruce Biendarra
(3,609 Views)
Hey Bruce,
Have you thought about using Functional Globals to pass the FPGA reference back and forth between VIs contained within the same project?  I'm don't have a strong FPGA background (our support structure allows us to choose product areas in which to specialize) but I do know that the FPGA reference is a pretty complicated type and I think that Functional Globals are the way to go.
Is there a good reason why Functional Globals wouldn't work?
Derrick S.
Product Manager
NI DIAdem
(3,573 Views)
Biendarra,
Another way to do this would be to flatten the reference to a string before you pass it to TestStand, store it in a string propertyobject, and then unflatten it when you pass it back to LabVIEW.
You can find the Flatten/Unflatten to/from string in the LabVIEW palette under Programming»Numeric»Data Manipulation
Josh W.
Certified TestStand Architect
Formerly blue
(3,552 Views)
I did finally get it to work by unbundling the handle and passing out the components to Test Stand and I then passed the information back into the other VIs I was calling and Re bundled the cluster.  It wasn't prety but it worked.  Adding a FPGA Handle type to Test Stand May be a good idea as I can see these devices used often in test systems because of their adaptability.
Bruce Biendarra
(3,546 Views)
