NI TestStand
Passing and Receiving Struct from Test Stand
Hi All,
I have this DLL with this function:
long __declspec(dllexport) InitMyNodeID(char* nameNode myData* mh)
 GimmeMyNodeID(nameNode, &mh->myNodeID);
struct myData {
int myNodeID;
 Notes:
 GimmeMyNodeID is a standard API that receives nameNode as input and returns an int myNodeID.
I'm having difficulty receiving it on the test stand parameter...
Can somebody help me on this..:o)
(3,300 Views)
Ray,
in order to pass structs as parameters from/to TestStand, you have to define a datatype. In the typedefinition, you can set a property which is called "Allow Objects of This Type to be passed as Structs".
Then you have to create a variable using this type and there you go 🙂
hope this helps,
Norbert
Norbert
Expert: Geometry
(3,298 Views)
Hi Norbert,
Do you mean define the data type in the test stand environment?
(3,289 Views)
Yes, in anywhere in the typepalette (i would suggest using the SequenceFile).
hope this helps,
Norbert
Norbert
Expert: Geometry
(3,279 Views)
