NI TestStand
Passing in formula as a string
I am attempting to use a string parameter to contain a formula that, when passed into a called sequence, will populate the value of another string and be evaluated as a formula.
E.G.
CalledStep has:
a string parameter called Name,
a number local called Val, and
a message popup step with a precondition to only run if  name equals Carl.
MainSequence :
is needs to pass in a formula for the parameter Name, so that inside CalledStep the name changes based on Val.
I have tried using "Parameters.Name = Locals.Val == 2? "+ Str("Carl") + ":" + Str("Jim") (with quotes as depicted), but it doesn't work. Watch view shows the equation in Parameters.Name but I suspect the quotes on the whole statement make it, just another string, instead of a working equation.
Is there a way, either in CalledStep or in the MainSequence to cause the above equation to be evaluated once inside the called sequence? Can I remove the quotes in CalledStep? Would I use an Expression (string) parameter?
Thank you for any help you can provide.
(5,127 Views)
I didn't expect to figure it out myself so quickly, but I didn't want to wait until I'd wasted days already to post. Anyway, I have included a sequence file that accomplishes my goal and I hope it can help someone else out.
I used "Parameters.Name = Locals.Val == 2? \"Carl\" : \"Jim\"" to get the equation into CalledStep and then, once within, I used the evaluate command to look at the string as an expression. The result can then be stored in locals by equating two variables (i.e. locals.string = evaluate(parameter.name)), or by directly inserting it where I need the value.
(5,120 Views)
Hi
have you ever tried to use " instead \" this show work, too
if it is neccessary to have the " in string then forget this message!
Regards
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(5,091 Views)
It depends. If you want the quotation marks to remain in the Evaluate() function then you need the \" \" to keep the values between them as a string. If you want them as parameters, then the quotation marks are unnecessary. Also, if you are saving the formula in a string parameter you need and additional set of quotes around the whole formula, but if you are entering the formula into a sequence call parameter then you leave them off.
Thank you for replying.
Jason
(5,077 Views)
Hi Jason,
Good explanation. Thanks for sharing.
Hope to read more answers from you in future here.
 - Time to spend another kudo.
Juergen
--Signature--
(5,071 Views)
