NI TestStand
Password Protect Sequence Files on Deployment
I need to password protect (not viewable) my sequence files for a deployment (many sequence files will be included).  I would rather not do this file by file for the deployment (files are in a version control system, and need to be updated regulary, so, having individual developers set passwords to individual sequence files to build is tedious at best).  Is there a slick way of doing this so that the source sequence files don't need to have this enabled one by one through Edit -> Sequence File Properties, but the deployed ones do (just like you can password protect the LabVIEW VI's through the TS Deployment Utility)? Suggestions?
CLA, CTA
Not my tempo... AGAIN!
(4,894 Views)
Having searched around a bit, it looks like the ability to password-protect a sequence file in the sequence editor or operator interfaces was introduced back in TestStand 3.5.  However, while you can set passwords for VIs in the TSDU, I unfortunately don't believe you can do this for sequence files through the TSDU.  This might be a good thing to post on the TestStand Idea Exchange:
http://forums.ni.com/t5/NI-TestStand-Idea-Exchange/idb-p/teststandideas
Michael Keane
(4,781 Views)
Done,
Please get those kudos rolling!:
http://forums.ni.com/t5/NI-TestStand-Idea-Exchange/Set-Password-Protection-and-Lock-Sequence-Files-f...
CLA, CTA
(4,739 Views)
