NI TestStand
Persistent deployment error.
It looks like perhaps he has mixed-mode libraries on the machine or has something cross linked in the NI library tree OR the reportlib is fubar. .
Try using the development Labview engine and open the VI's giving you trouble from the TARGET directory ( SupportVIs directory) and see if the VI hierarchy is coming from the location you expect. If you can open the "offending" VI you should be able to chase down where the VI tree is messed up.
So open C:\__views\calTest_jvh\mastrv\Deployments\MASTRV-CalAndTest\target\SupportVIs\NI_report.lvclass with Labview and look at the FULL VI tree to see what is called out and missing.
Also open the Dialogs\Dialogs.lvlib lib in the TARGET path and see what that calls.
Post the deploy log too.
Message 11 of 12
(873 Views)
Some directories, exes, and sequence files were created but not the SupportVIs directory, nor the DeploymentUtility.log file. At termination there is an option to save the log file but it is the same as what I posted.
thanx,
jvh
Message 12 of 12
(869 Views)
