NI TestStand
PopUp window sometimes in the background
I have programmed a PopUp window (programmed in LabWindows compiled as dll). I call this dll in teststand and somtimes (often) this PopUp window is in the background (behind my OperatorInterface). What can I do that this window is always shown on the top?
thank You
regards samuel
(3,300 Views)
Maybe you can use a modal dialog.
There ia an example here http://zone.ni.com/devzone/cda/epd/p/id/3602
It for TestStand ver 1.01 but you should be able to modify the DLL project for a later version of Teststand.
Regards
Ray Farmer
Regards
Ray Farmer
(3,295 Views)
Hi!
I have the following problem:
I made a DLL with Builder 6, which creates a modal window. When I run the DLL from TestStand, the window stays in the background (in windows xp, under win2000 it works fine).
How can I show the window in front of the teststand?
Thx
Dave
(3,083 Views)
