NI TestStand
Post Report Generation step
I'm building a test automation system using TestStand, and I want to send my HTML test report by email to the operator.
How can I add a step to send an email after creating the report?
I tried using the "GetReportFilePath" callback, but it executes when the file path is fixed (the report file is still empty at this point) and not after the HTML report is generated.
I would like to execute the step to send the email after the report generation is complete.
Any help would be greatly appreciated.
Thank you and best regards.
(896 Views)
Depending on the model you are using, the report(s) are created in
  • Model Plugin – UUT Done
  • Model Plugin – Batch Done
 from the process model. So immediately after one of those might be a good location
(873 Views)
