NI TestStand
Post expression use of condition statements
Hi all
the  expression   Field for  a step  does not allow use of   If else   statements
should I take it  as "limited" feature of teststand  & use the Statement-step or am I misled!
(5,729 Views)
I think  If else cant be used in "expression"
may be I have to use the flow control
(5,728 Views)
What exactly are you trying to do?  If you are trying to set a value, then it can be done.
locals.num = locals.bool? TrueValue:FalseValue
(5,724 Views)
I wanted to use  the If else  condition statements
but  now I am able to do the same with "?:"
(5,722 Views)
It's true that expression allow only "a boolean select".
What is the use case for more complicated selections with more than two options?
Why is it beneficial to implement this as a step component (that means: obfuscating options) instead of displaying the selection in an obvious, readable way as multiple steps?
Norbert
Norbert
Expert: Geometry
(5,718 Views)
