NI TestStand
PostStep Callback Question
I understand how to use this Callback, however, the sequence that executes my tests is built dynamically. (Hence, tests are selected on-the-fly and the Test Sequence is built dynalically using Active X functions.)
My question: How can I use the PostStep Callback in this dynamically built sequence. (The Callback is supposed to reside inside the test sequence itself)
Thanks.
Kevin
(3,076 Views)
I placed the Callback inside my Process Model and it seems to run, but only after all tests are executed. What I need it for it to run after each test, if there's a failure.
Thanks again.
Message Edited by kevmi2ca on 01-10-2008 11:50 AM
(3,075 Views)
Nevermind. I used the ProcessModelPostTest Callback and it worked exactly how I wanted.
(3,073 Views)
