NI TestStand
Precondition string compare problem
I can't believe I have to ask about this, but I am so confused why it doesn't work. It should be simple.
FileGlobal.ProductID = "07"
This is a string.
Why then, does this expression evaluate to True?
FileGlobals.ProductID == "01" || "02"
In order to debug, I made a Pass/fail step with it's Data Source expression set to:
(FileGlobals.ProductID == "01" || "02") ? (Step.Result.PassFail = True) : (Step.Result.PassFail = False)
This also evaluates to True.
I want it to be True for "01" or "02", but not for "03" etc...
(4,195 Views)
Accepted by topic author DrOnline82
I found this in the expression builder for "logical or":
String operands are converted to True if the text [...] contains the representation of a non-zero number, False otherwise.
This seems like odd behavior to me, but I'll just have to work around it. I didn't know this.
I'm trying to use StrComp(), but I can't make heads or tails of the documentation here:
https://www.ni.com/docs/en-US/bundle/teststand-api-reference/page/tsfundamentals/strcomp-function.ht...
"A number less than 0 if the first string is less than the second. A number greater than 0 if the first string is greater than the second. 0 if the strings are equal."
What does it mean for a string to be great than another string? Mathematically?
StrComp("Buddy","Budgy") evaluates to -1
StrComp("Budgy","Buddy") evaluates to 1
I don't understand the logic here.
If anybody can shed some light on this for me, it would be appreciated! I've decided to solve it in LabVIEW instead. What I want is a TestStand expression like this: StringsMatch("01","01") evaluating to True (boolean)
(4,183 Views)
FileGlobals.ProductID == "01" || FileGlobals.ProductID == "02"
The problem with "FileGlobals.ProductID == "01" || "02"" is that you're actually checking here if:
(FileGlobals.ProductID == "01" is TRUE) OR ("02" is TRUE)
While the first part is false (because FileGlobals.ProductID is actually "07"), the second part is true ("02" converts to boolean as TRUE) which results in TRUE as the "OR" result
Mateusz Owczarek
Certified LabVIEW Architect
Certified TestStand Architect
(4,157 Views)
Holy cow I spent a lot of time on this. And it was that simple... Thanks Mateusz!!
(4,153 Views)
Glad I could help 🙂
Mateusz Owczarek
(4,148 Views)
Yes, I see you added more to your answer. After you posted your answer I understood the same thing as you described it.
(4,134 Views)
